hi
i have installed titan simulator but i'm unable to activate the software in no way ...i have tried changing compatibility mode to xp or vista i still get the same error message ( An error occurred while attempting to generate an activation code: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
i have been installing , uninstalling , tried offline activation and internet activation nothing seems to work
i have windows 7 ultimate 64 bit , i wonder if this is the problem (64-bit) i have tried installing it on my laptop which also have windows 7 home edition 64 bit i also had the same problem in activating
i began to think it's not designed for x64b ..is it designed to work on 64 bit ? if yes then what would be the problem
thank you
titan simulator activation problem
themastermix
