Palettes
GaryShooter
Palettes
Postby GaryShooter » 11 Dec 2012, 10:20
I've been following the Titan One "Quick Start" guide, and found the section on Palettes in section 7 a good introduction.
My expectation regarding Palettes was that I could create a Palette, use it in a number of Cues, and any future changes to the Palette would be reflected into the Cues that use it. After reading section 5 of the v6.0 Titan Mobile manual my expectation was confirmed, with the manual describing how a reference to the Palette is stored in the Cue, rather than the actual attribute values.
So, I gave it a go. I created a colour Palette, created a Cue List, and applied the Palette to one of the Cues. All good so far.
I then went back and modified the Palette, and then viewed the Cue that contained the Palette. What I find is that although the Palette has been successfully modified, the Cue still contains the old values for the Palette.
I assume I must be doing something wrong. Maybe, when I apply the Palette, I have to do something "special" in order to say "refer to Palette " rather than "use the absolute values". I checked the Titan One Quick Start guide, but in section 8.1 "Record Modes" on Page 13 it just says "Apply a band position palette and a colour palette", so I assume there isn't any more to it other than clicking on the Palette to apply it to the Programmer.
Any help would be appreciated!
Thanks,
Gary
Postby niclights » 11 Dec 2012, 11:18
It's a bug with cue view. The palette reference definitely works.
GaryShooter
Postby GaryShooter » 13 Dec 2012, 16:13
Thanks for the reply Nic. I agree that the palette works as expected, and that it is just the Cue view that is wrong.
AndrewRPage
Re: Palettes
Postby AndrewRPage » 15 Jul 2013, 21:03
I realise this is a an old thread but didn't want to start a new one.
I have a show where pallets form the building blocks of cues in a Cue Stack (non tracking).
I have modified one pallet using the pallet view.
Yes if I just trigger the original pallet it has changed BUT none of the cues in the Cue Stack using this pallets have updated. :cry:
Also where is the "Update pallet" the button or its equivalent.
Andrew
Re: Palettes
Postby niclights » 15 Jul 2013, 22:09
I have not been able to repeat this in 6.1. I record a couple of colour-mix palettes, clear, start recording cue-list, select fixtures, select palette 1, record cue 1, select palette 2, record cue 2. View palette 1, change values, replay list = new colours in cue 1. Turn off tracking. View and adjust palette 2. Replay = new colours in cue 2. Please post consistent steps to repeat from new show if you are able.
Edit palette button is named Edit.
AndrewRPage
Re: Palettes
Postby AndrewRPage » 25 Jul 2013, 21:23
Sorry to take so long to respond to your very quick reply.
But did not want to mess about during the show, even with a new play file Just In Case.
Anyway I have not been able to recreate the problem.
The palette was a normal with Intensity and colour included, I had adjusted the Intensity and saved it but it had not changed the intensity.
Not sure what I did wrong but it all works fine now
I think put it down to operator error.
Thanks again
