Hi, i have just setup my titan one software but the touchscreen is not working. i have a dell st2220t screen running on vista. the dell is the second screen. when i start titan one it puts its self on my main screen then i have to move it over the the dell. please can you let me know what i am doing wrong.
thanks
richard
touchscreen setup
touchscreen setup
after i move the titan one window to the touchscreen and then touch a button titan one stops working? the dmx side is working fine.
I have heard of one other case where it turned out that the touchscreen driver was interfering with the normal operation of the Titan software. In that case it transpired that it would make other applications written using the .NET Framework to become unstable, this includes applications such as Nero 9. Unfortunately without having the touchscreen in front of me, it is difficult to know if this is actually the case in this instance.
I would suggest that you look at the configuration settings for the touchscreen and see if there are any options to switch to single touch or basic operation mode. Alternatively see if there is a newer or alternative driver that may work better or provide more options.
hi, i still cant get my touchscreen to work, it still crashes Titan one as soon as you touch the screen. i have looked for an alternative driver but dell does not seem to have one. i will be coming in the do the Titan foundation soon so can i bring my screen and a laptop in to you to have a look at? of do you have any other suggestions?
