Virtual pannel Expert Titan v6.1?
Ferran
Postby Ferran » 22 Nov 2012, 14:49
Hello.
Where is the virtual panel in Expert Titan?
Thank you.
Postby niclights » 22 Nov 2012, 15:15
Same place as previous versions - Tools/Additional Programs
Ferran
Postby Ferran » 22 Nov 2012, 15:27
Hi nic, look there, but does not appear on my console. In aditional programs only appears: Command Prompt, log Collector, Personality Builder, Titan HealthChec, Web Broser and Winamp.
Ferran
Postby Ferran » 23 Nov 2012, 08:40
In that folder should be virtual pannel?
Ferran
Postby Ferran » 26 Nov 2012, 16:54
Hello.
Anyone feels the same?.
I can not find the virtual pannel.
I need to control the console remotely via TeamViewer.
Thank you.
Postby niclights » 26 Nov 2012, 17:22
Sorry, I forgot about this. I can't understand why it wouldn't be there but you could try installing it manually. Hopefully the installer should exist in C:\Program Files\Avolites\Install. If not you can extract it from the main install executable using something like 7zip.
Postby icke_siegen » 26 Nov 2012, 17:22
I don't have a Pearl Expert at hand right now, only a Tiger Touch running 6.1. And the Virtual Panel is in c:\Program Files\Avolites\Virtual Panel. Either start the VirtualPanel.exe, or (preferably) select Tools -> Additional Programs -> Virtual Panel (of course you need to hook up an external screen to access the tools menu)
Postby icke_siegen » 26 Nov 2012, 17:25
And something else comes top my mind. Every now and then I saw windows installing the Virtual Panel the first time I started the Simulator on a computer (not a console), which leads me to the assumption that on some machines the installer doesn't complete its job. However, neither could I track this, nor log it :(
Ferran
Postby Ferran » 26 Nov 2012, 18:11
Thanks for your answers.
Tomorrow I will try.
Thank you again.
Ferran
Postby Ferran » 03 Dec 2012, 16:39
Hello.
Finally I was able to install the virtual pannel from C: \ Program Files \ Avolites \ Install.
Virtual pannel as shown in aditional programs.
