Hello, I'm writing a personality for a RGBW led bar. This bar has two different modes, 8ch and 36ch. OPerating mode is controlled by the value of channel 3. 0-40 is 8ch mode, 41-80 is 36 ch mode.
I made the personality file with two modes. Can I set the value of channel 3 in the personality and lock it ? 20 for mode 8ch and 60 for 36 ch ? How can I do?
setting a fixed dmx value for different modes on a led bar
Thanks, It works!
Another question: Titan Manual says the right place to save user personalities is MyDocuments/Titan/Personalities. I created the directories, put the personality and then restarted software but nothing. The only valid directory to put personalities into is d:/TitanData/Personalities
What I'm doing wrong?
On consoles since v6.0 the location for personalities is:
d:\TitanData\FixtureLibrary
(note that this directory might be hidden by default)
On PC (TM/T1/TS) the location is:
\program files\avolites\titan\fixturelibrary
(The intention is to have a separate location for custom personalities which would take priority. The locations for these are d:\personalities (consoles) and my documents\titan\personalities. However, at the time of writing this function is not working.)
Hi Niclights, Do you know when this will be working On TH
Its a real pain in the a*** having to put your fixtures in the fixure libary every time you make them or edit tehm. In win 7 its almost impossible to add/edit them because of window 'ownership'
A file in docs is the way to go and the sooner the better.
I do not. Although I guess it would be reasonable to assume v7.0.
In the meantime you can solve the ownership problem with widely available registry hack that adds a 'take ownership' option to the explorer right-click menu. Something every W7 user should never be without. Google 'win 7 take ownership' or similar.
I was already considering making c:\program files\Avolites\Titan\FixtureLibrary a symbolic link to the new location. Haven't tried yet, but probably this would be a solution for this weirdness.
