Desk Light
devnull
Desk Light
Postby devnull » 09 Oct 2012, 19:05
Ho can I connect a desk led light to the Titan Mobile console? What is the plug under the external power connector?
Postby icke_siegen » 09 Oct 2012, 21:08
You cannot. What I know some people are using is a USB powered (gooseneck) light, connected to the computer/laptop which drives the mobile.
The connector you're referring to is a ground (earth) connector - I've never used it, and know none who has.
devnull
Postby devnull » 10 Oct 2012, 18:22
thanks! :)
MbeNL
Desk Light at T6 (Pearl Expert Titan)
Postby MbeNL » 26 Oct 2012, 18:40
When there was an update for Titan (the first of it) I can dim the desklight at the System menu inside the software. But till version 6.0 there isn't an bug fix, to do this again. Last week I was on tour and I cant dim my desklight. It is just not professional to place an small piece of an LEE filter on top of my desklight. Maybe an suggestion to fix this bug?
I think it is inside the software, there is an small change that it can be my desk light, but when it says to be at 0%, the light is still on...
The problem is at the Pearl Expert Titan with V6 (also at earlier releases).
Postby niclights » 27 Oct 2012, 22:25
I cannot find any problem with desklamp control. I suspect you have a hardware fault. What sort of desklamp are you using?
Users browsing this forum: Google [Bot] and 145 guests
