Is it possible to play back an audio file from the tiger touch from winamp out the 1/8th" jack in the back panel ?
and would it also be possible to have timecode coming from winamp to Titan for cue-stack trigger ?
I have a simple show and need to program lighting to 2 songs.
Audio playback from console
ChrisLITaz
Chris LIT
Lighting Designer
Project Manager
Creative Backstage Tempe AZ.
creativebackstage(dot)com
Chris(at)Creativebackstage(dot)com
Lighting Designer
Project Manager
Re: Audio playback from console
it is possible as i recall.
i once had a simple test with audio out from winamp with timecode.
you just set the console's timecode source to winamp and edit times for each step,raise the fader,hit play in winamp and everything just goes....
i can't remember details but it sure will work.it was in titan5.0
Users browsing this forum: No registered users and 123 guests
