Tiger Touch v6, Importing user made personalities.
funkyant
Postby funkyant » 07 Sep 2012, 18:10
Hi there.
I've had a go at making a personality for a fixture, and found the Quick Start Guide quite helpful, and didn't seem to hit any real problems making the personality.
My problem is that I can't get the console to see it at all, and I'm really not sure why.
I copied the file to c:\Program Files\Avolites\Titan\Fixture Library and restarted the console - but when I go to patch the fixture, it's just not there.
Any ideas why would be greatly appreciated.
The .d4 file can be downloaded below:
http://www29.zippyshare.com/v/67924395/file.html
Thanks in advance.
Ant
Postby niclights » 07 Sep 2012, 19:17
Nothing wrong with the personality. Personality location has changed. You need to place it in D:/TitanData/FixtureLibrary/
Note that you may have to change folder options to show hidden files & folders. The idea is that you should be able to use D:/Personalities for your own ones but it's being naughty and refuses to work at the moment.
funkyant
Postby funkyant » 07 Sep 2012, 21:43
Aaaaaaaah.
Thank you so much! Works a charm when you put it in the correct location :)
