Clear LTP
eugenumail
Clear LTP
Postby eugenumail » 04 Sep 2012, 14:07
I use a Sapphire 2000 and i would like to know if it`s possible to bring a LTP channel to 0 by pressing "clear". If it`s possible without modifying the personality file.
Thanks.
Postby niclights » 04 Sep 2012, 15:45
Sorry, this is not possible.
eugenumail
Postby eugenumail » 05 Sep 2012, 10:53
Thank you for your quick reply. I have one more question.
Why is it that i can save a memory with some fixtures that are just "located".
Everything is included in that memory:pan,tilt,dimmer,shutter,iris... I thought
"locate" does not add anything to the programmer.
Thank you very much.
Postby niclights » 05 Sep 2012, 11:26
My guess would be that you are recording 'by fixture'. In this mode all attributes for any fixtures that have been selected will be recorded, regardless of whether they are in the programmer or not. 'By channel' will only record values in the programmer.
Use the softkeys to toggle the mode after pressing record.
eugenumail
Postby eugenumail » 05 Sep 2012, 12:38
That`s it . Thank you.
eugenumail
Postby eugenumail » 05 Sep 2012, 13:02
Just now i was testing in the pearl simulator if shapes can be included
in chase steps. and it worked and looked great. But the chase menu of the Sapphire does not have the shape generator function. Will there be a software update witch will make this possible?
Postby niclights » 05 Sep 2012, 16:27
As far as I am aware the Sapphire 2000 software is no longer in development. However, it might be worth checking you have the latest version (Build 5) and updating if not. See here for more details.
eugenumail
Postby eugenumail » 06 Sep 2012, 14:46
I`m sorry to hear that :( . Thank you.
Users browsing this forum: No registered users and 66 guests
