Hello....
I have the Titan Mobile 5 and it have had a problem each time I acidently hit the effect button... But after I had installed v6 it work and I can finaly test the Pixelmapper...
My testsetup is:
4pc ledbar wid 18RGB pixels
Channels:
1 Masterdimmer
2 Masterstrobe
3 Programs
4 Program speed
5 Master Red
6 Master Green
7 Master Blue
8 Cel 1 Red
9 Cel 1 Green
10 Cel 1 Blue
11 Cel 2 Red
12 Cel 2 Green
and all the way to 61...
When I go into the Pixel Layout I can see an array of 4 x 18 pixels so the array is right with what I got.. BUT when I make forexample a circle the first pixel in each column work and it sets channel 5,6,7 on each bar... It should have been the adress 8,9,10 and the row under should controll 11,12,13...
If I Unfold the lamps i can get the Cel working separatly in Shapegenerator so the Peronality file seems to work..
The strange thing is that the Pixel array is on the Cels but it only controls Master RGB.... So it get the correct number of Cels/Pixer but work as iw has 4 x 1 Pixels... Any ideas?
/Niklas
Pixelmapper with Cels
DeeJay_Bamse
DeeJay_Bamse
