no USB option in system settings for pearl 2008
longhair13
Postby longhair13 » 24 Aug 2012, 06:09
I am not getting the USB option in the menu when in system settings menu. also do not get the sync fixture option either. please help.
katiandmario
Postby katiandmario » 21 Nov 2012, 18:52
I have the same problem!
longhair13
Postby longhair13 » 19 Dec 2012, 04:57
:x :x :x :x :x i don't understand why nobody has an answer for my problem especially since I'm not the only person experiencing this problem. can someone please help.
Postby icke_siegen » 19 Dec 2012, 10:50
Putting it bluntly, Kati's problem turned out to be due to a chinese copy. And due to the advanced software protection from version 2008 on, the software doesn't run on non-genuine hardware.
Of course none here wants to accuse you to run a copy - and that's why many people are hesitant to answer.
Postby Gregory » 19 Dec 2012, 11:45
Please ensure that the console is running the latest version of the AVOS and the software. It is possible that the console is running the Pearl 2004 software and therefore this is why the USB options do not appear. Note that some of the early 2008 consoles were sold with the 2004 software before the new software was released, some of these may not have been upgraded yet.
jesperspier
Postby jesperspier » 19 Dec 2012, 15:41
Lets say you have the latest AVOS and 2008 software running. On a real Avolites console. Go to the System menu with your key.
there you can press ‘B – System Information’ to check that the USB Memory Board is working. There should be a date below the ‘USB Memory Board:’ line, and it should display how many memory sticks are plugged in. (Remember that there is one inside the desk).
If not, i guess it's a hardware failure. (than contact your dealer or Avolites by e-mail)
(We had a few pearls with software crashes that was caused by bad default USB sticks supplied on the usb board. Replace of that USB solved the problem)
Users browsing this forum: No registered users and 66 guests
