Titan with ESP Vision
DUSTINSNYDER
Postby DUSTINSNYDER » 22 Aug 2012, 03:53
Hello. Do you have any advice on getting Titan 6.0 to connect with ESP running on the same PC? I can see the avo vis just fine. In esp I have turned on avolites consoles under DMX settings, but no luck. I remember on non-titan versions you would need to install ADCI, so I tried that as well, but the program wouldn't open. I'm running windows pro 64 bit and a titan mobile.
Thanks,
Dustin
Postby niclights » 22 Aug 2012, 07:34
I don't have ESP to test but usually the best way is to use Art-Net. When on the same machine use IP 127.0.0.1.
