"OFF" Function on Titan
pixantz
Postby pixantz » 20 Aug 2012, 21:32
I have to press almost a dozen buttons to set even a single fixture OFF from a Cue, selecting all the attributes and what-not(Titan). Its easier on the Classic. Can't you guys at Avo provide a Mask or something like we have for, say, 'Clear'?
Postby niclights » 20 Aug 2012, 23:25
There is certainly room for improvement but I'm surprised you're finding it that bad.
For whole fixtures:
- Select fixture(s)
- OFF
- [Selected Fixtures Off]
For attribute groups:
- Select fixture(s)
- OFF
- Toggle groups with attribute banks
- [Attributes Off]
Admittedly individual attributes are not ideal at the moment as the softkeys only populate when you first enter the OFF menu.
If you need to remove individual attributes from an existing cue then I find it easiest to use cue view and select the cells followed by [delete]/[confirm].
Users browsing this forum: No registered users and 80 guests
