Hi guys
is it possible to record effects from the effect generator on pallets on expert touch wing?
record effects on pallets (Titan)
Best Regards
Jacob Andersen
Designer | Technician | Rigger
Jacob Andersen
Make sure FX is included in the mask. If you are recording to the Shapes and Effects workspace then it should store by quick record as well as Record Palette/<select handle>. If you are recording to any other palette workspace it won't work with quick record but as far as I know should be ok with Record Palette/<select handle>.
