White Color Shape
Stratis
White Color Shape
Postby Stratis » 30 Jul 2012, 18:53
I just patched some moving heads with RGBW leds and noticed that there isn't a shape for the white ones like the rgb ones.Is it added on Titan v6???
The fixtures are the american dj Inno color beam on tiger touch
Postby niclights » 30 Jul 2012, 19:43
I don't think so. It's very easy to do though. I have been intending to propose doing work on the shapefile for some time but have been too busy. I'll try to get on it.
Stratis
Postby Stratis » 30 Jul 2012, 23:44
If you have a small number of fixtures it's easy but it would be great if there was a shape as most of the LED fixture come with white ones too.
Postby niclights » 30 Jul 2012, 23:53
I meant that it is easy to add a white shape to the shapefile.
Stratis
Postby Stratis » 28 Aug 2012, 17:02
it would be great & very useful if it could be added to the shape file...Thank you for your response
cortipi
Postby cortipi » 28 Aug 2012, 19:46
It would be great also to have amber shape for fixture with RGBAW led (I have a lot of Leader Light Stage and Pro Wash).
Thanks a lot
Pietro
Stratis
Postby Stratis » 14 Sep 2012, 21:41
I edited the shape file and added white and amber shapes.I tested it with titan simulator and capture simulator and works fine and i will test on a tiger touch next week.Here is the shape file :
https://www.dropbox.com/s/zktru1hrcs99st2/Shape.xml
Postby niclights » 14 Sep 2012, 22:24
Looks good to me.
Stratis
Postby Stratis » 14 Sep 2012, 23:27
The shape file will be replaced every time i update the personality library???
Postby niclights » 15 Sep 2012, 00:05
Yes.
Stratis
Postby Stratis » 15 Sep 2012, 12:10
So someone from the avo team must add it to the personality setup file or we will have to replace it every time we update the library.
Postby niclights » 15 Sep 2012, 13:39
That is correct.
Users browsing this forum: No registered users and 120 guests
