Hey all,
Having trouble with a DL3, trying to troubleshoot it with two consoles, with the Avolites I use the Catalyst DL3 Profile, and I dont get any pan, tilt, or any control.
I can get Pan/tilt with the hog3 on the same dmx line, hot swapping it out, but Im having other issues with content, etc.
End goal is to use the Avo for sure, does anyone know if V1 or V2 on the DL3 matters, and which one to use with the profile?
ANy other tips from people who have learned tricks on it would be awesome as well.
Also, can you use the fixture attributes to see the media uploaded to the unit?
billy
Patching a DL-3
Billyserious
Billyserious
Looks like there is only a v1 personality at the moment so it should be v1 on the fixture. Patch Master then Global then Object x3 consecutively where Master begins at the start address of the fixture. If this doesn't work then can you confirm DMX reception on the fixture when connected to the Avo console?
Media requires CITP thumbnail support. AFAIK this is not available.
Users browsing this forum: Bing [Bot] and 32 guests
