Pearl 2004 not show ranges attributes
Ferran
Postby Ferran » 16 Jan 2012, 12:51
Hello
I have a Pearl 2004 with Software 1.2 July 11 2004 that do not shows the ranges of the attributes in the wheels, it only shows the name of these. Before if revealed. The Cahe files is the same that I use for other consoles working properly.
Thank you.
Postby niclights » 16 Jan 2012, 13:48
Make sure it is set to display intelligent attributes. Toggle with Shift+1.
Ferran
Postby Ferran » 16 Jan 2012, 15:08
Thanks for responding.
The inteligent display is active.
I have not compared to another console, but when you tap twice View button the display shows: Please wait, Energising the Pearl. Is this normal?
Thank you.
Postby niclights » 16 Jan 2012, 15:11
Yes, that is normal.
Ferran
Postby Ferran » 16 Jan 2012, 15:15
Thank you.
No never seen before.
As for the ranges are not displayed, you know something?. It's very strange, before a few days ago if she was.
Thank you.
Postby niclights » 16 Jan 2012, 15:32
Try performing wipe-all and patch a fixture you know has ranges from a normal floppy (rather than the cache).
If that works then try cache.
Ferran
Postby Ferran » 16 Jan 2012, 15:37
I already did, but not working. The same cache when working well on other consoles.
Thank you.
Ferran
Postby Ferran » 18 Jan 2012, 09:47
no solution?
Postby niclights » 18 Jan 2012, 10:27
Sorry, I don't have any ideas.
Ferran
Postby Ferran » 18 Jan 2012, 10:34
Thanks niclights.
I hope someone can help me. I do not think the problem is the library, also works on another console. Maybe the Boris, a memory sector ...
Users browsing this forum: Baidu [Spider] and 40 guests
