Pearl Tiger not rembering chase timing
Tom Mayer
Postby Tom Mayer » 15 Dec 2011, 17:16
Having issue with Pearl Tiger .r20. Built several chases, loaded into submasters, adjust crossfade to 0 0 0 and set timing as desired. Come back to that fader after doing same to other subs and timing is back to default setting (.02 & ff ff ff)
Tom Mayer
Read the Manual
Postby Tom Mayer » 15 Dec 2011, 17:24
Found the reason for my issue. Thanks anyway....
Olie
Site Admin
Postby Olie » 16 Dec 2011, 17:39
For other's reading this post, the chase speed times are not saved by defauult. You have to specifically choose to save them in the Edit Times menu.
In Titan it is the oposite and times are saved by default unless you select the user option to not save the times.
