Is my Titan Mobile has problem?
StageProVN
Postby StageProVN » 26 Nov 2011, 12:37
Hi ,
I have new Titan Mobile run V5 and it can not access to system menu. I want to find the trigger menu to add my padkontrol. I tried press hold Avo + Disk but it only show in my laptop's screen : newshow, loadshow , saveshow and one option(don't remember). I tried to restart but it still didn't access to the system menu.
How can i solve that?
Postby niclights » 26 Nov 2011, 13:30
The shift key should be immediately underneath the grey 'group' key. I remember someone else had a similar problem where the shift key was in the wrong place. If this has happened you can swap the keys by carefully levering off and moving.
Postby icke_siegen » 26 Nov 2011, 13:33
Is the Avo key working at all? Maybe the key had a mechanical issue.
Quick workaround: the shortkey on the Notebook keyboard: Alt+Shift+S
Postby icke_siegen » 26 Nov 2011, 13:36
Yeah Nick, you're right, once I had a Mobile where Shift was swapped with Set immediately underneath. Just replacing the key caps did the trick.
peter.rodda
Postby peter.rodda » 29 Nov 2011, 10:59
does the Set button have a function in version 5 yet?
Users browsing this forum: No registered users and 96 guests
