I am using avolites 2010 console. I often save shows when I finish a TV show for back-up. Recently, I find once I load saved shows from my USB back to console, some fixtures cannot be in the correct situation.
Example: I memory my first playback with all VL3000 to the title 75 and with rainbow, and all martin with color pink. Then on my second playback, I create 3000 with title 45 and with color blue, I do not change martin situation, then I press memory (channel = fixture model =0) and playback 2. After I clear up memory, first I use playback and then pull it down, up the second playback, intersting: 3000 cannot be replace to my second record status, they are still title 75 and with rainbow.
The way I deal with that is to wipe the console and do everything again,it is OK. And I find that problem could only be happened to one kind of fixture, If I change martin at second playback, martin will be fine. I feel puzzle about that.
The problem happens sometime, but you know I should do more for every TV shows'records
I feel strange,hope U know the answers
