I have installed Titan version 5 on the Tiger Touch and created my first pixel mapping on some led bars.
How can I do pixel mapping on each CMY/RGB channels of one fixture? Or is the pixel mapping only for complete fixtures?
Kind regards,
Sybren
Titan 5 pixel mapper
Have you updated your fixture library?
What you're asking for is oing along with a feature called 'subfixtures' - if you patch such bars/battens, console should automatically know its cells. Try <Unfold> and the patched fixture; a new window should appear with all the individual cells - which will be recognized by the pixel mapper.
Else, if that unfold thing doesn't work, and instead you can toggle to different RGB/CMY pages, then your fixture library is probably outdated.
Please refer to the manual, 'subfixtures', for more details.
icke_siegen wrote:Else, if that unfold thing doesn't work, and instead you can toggle to different RGB/CMY pages, then your fixture library is probably outdated.
Not necessarily. There are a large number of files to update and not all have been yet. I've done somewhere around 2/3rd's of the library with the more common fixtures prioritised.
If, after updating, your fixture still has the RGB in pages rather than as subfixtures via unfold then let me know which fixture it is and I will sort it out for you.
None of the Atmosphere (or other fixtures) types is unfolding.
When selecting <unfold> and then the fixture, the fixture view is showing me only 1 fixture in the top left. (I also have to scroll up from the bottom of the fixture view...)
I have checked that the new fixture Personalities are in the right path and I can see them in the Personality editor on the Tiger Touch console.
Has it something to do with that I updated (from 4.0 --. 5.0) the Tiger touch in stead of a clean install of Titan 5?
Are you patching in a new show or is this an old show?
If it's old then you can use patch/[update personality] but due to the nature of sub fixtures this will unfortunately remove associated programming. Hopefully there will be a solution to this in the future.
If it is in a new show then do they show up in layout editor (create a group, [shapes and effects], [edit layout], select group)?
