cannot load individual fixture
zahoorjury
Postby zahoorjury » 29 Sep 2011, 23:02
:shock: hi there, i am using pearl 2008, i need to run a pr-lighting beam 300 on my console, i downloaded personality , its prxlB319 disk no 2008-2, but my conso;e is not reading the file and shows, NO SHAPE FILES FOUND. then says NO FIXTERS FOUND. But when i inspect my USB on my PC it shows that the personality is present in the stick. not only this personality the console refused to load any other fixter from UBB and as well as from FLOPPY.
and in the USB options console strangly backup on USB if i do.
any one HEeeeeeeeLp. regards
Postby niclights » 29 Sep 2011, 23:17
Did you use Copy 2008 to put the files in the correct place on the Usb stick?
zahoorjury
Postby zahoorjury » 30 Sep 2011, 01:12
no, i just used a specifc folder R 20. contain some other persnalities @ 18 mb. But not Backup 2008. I will try and let you know.
I also try Floppy with with 8 - 10 various fixtures as R 20. But the console shows, 1st folder ,Unknown. and 2nd. Only a single file displayed and when i try to patch on the handle . The display shows no sign of patching i mean the available dmv were vacaxt
Postby niclights » 30 Sep 2011, 10:22
I've seen exactly the same problem before but unfortunately I cannot remember the reason or solution at the moment. It was probably either lack of shape file (sg.dat), missing index or faulty file/filename (or a combination).
I suggest the easiest thing to do is use one of the full 2008 installers and sync the library. While this does take a while to complete it will be quicker than messing about trying to do it another way. It will also mean your library is up-to-date.
