Hi I have a question.
I tried to use the Capture with a Pearl, but I did not work.
I used a Midi In and Out cable connected to a computer, which is XP.
I opened a Capture software, ACDI, and AvoACDIToCITP.
I do not know why it did not work, so please let me know how to connect between the Pearl and Capture.
I checked it on an Avo website, but what I found was only a little detail.
Capture
If the ACDI is displaying a green indicator then it is most likely that it is going wrong at the capture end.
Unfortunately due to a limitation in the Capture software you must have a netwrok connection present to use Capture with the Pearl. I know this sounds odd but believe me it is true. We have contacted Capture and asked them to fix this problem.
If you do not already have a network connection then you have to fool capture into thinking it has one. This is done by simply connecting a hub to a network port and setting it up correctly.
You also need to ensure that in Capture you create a Universe and set the provider to Avolites.
Hopefully you will now be able to get it working.
