how to create fixture in visualiser
aymeric
Postby aymeric » 25 Jul 2011, 13:30
hello,
i use e lite servospot 250, with pearl expert with titan v4.1.
I find the fixture library in the desk, but they not appear in the visualiser, when i patch them.
I suppose because the servospot's library is not in titan.
How i can create it in visualiser? Or is here a other solution?
thank you
aymeric
Postby icke_siegen » 25 Jul 2011, 14:20
Use PersonalityBuilder for this:
- find the appropriate file in the fixture library (E-Lite_Servospot 250.d4)
- open it with PersonalityBuilder
- within PersonalityBuilder: File menu -> Generate R20 files
- copy the files to c:\program files\Avolites\Visualiser\Extensions (Vis) resp. c:\program files\Avolites\Visualiser\Personalities (R20)
- you might need to tweak the vis file a little (ranges will usually need some adjustment)...
aymeric
Postby aymeric » 26 Jul 2011, 14:10
ok, thank you
Users browsing this forum: No registered users and 71 guests
