Hi ,
i have two question for tiger touch ;
the first question is :
i want to copy a cue from the cue list and i push the unfold button then select cue list , after pressing copy button and selecting cue which is want to copy then i want to paste next empty button pressing by blue playback button but desk says : "select a handle to copy onto.You can't put that there"
is there any way to copy a cue from the cue list?
and second question is :
is there any chance to record cue list live ?? (i mean record real time..)
thanks.
some questions about "cue list"
EmmaThompson
1. The way to do this at the moment is to include the cue and re-record it:
in unfold, press 'include', then playback swop of the cue you want to copy. You can then re-record this as a new step.
2. Not sure what you want to record "live", do you mean timing?
Emma Thompson
Training and Events
Training and Events
EmmaThompson
I'm not sure if it's quite what you want but I do have a possible two-part solution:
First setup a cue-list with autoload playbacks in the correct order. Then set the timing live.
To setup the cue-list:
-Record Cue-List
-[Advanced Options]
-Turn on [Autoload Live Playbacks]
-Lift playbacks that you want to fire in the first cue.
-Store cue
-Lift playbacks for second cue.
-Store cue.
-etc.
Once you have build the list you can set the timecode points in real-time:
-Fire Cue-List and make sure is connected.
-[Timecode]
-Set timer source (ie. Winamp)
-[Record]
-Start the source time
-Press Go to set the timecode point for each cue in turn.
-Finish recording by pressing [Record] again.
-[Connected Cue-Lists]/turn on the list(s) to be controlled by timecode (this can be done by toggling the softkeys or by selecting the playbacks themselves.
-Reset the source timer and test.
-Manually edit times as required.
If you want the first cue to fire immediately then after pressing [Record] you could fire the first cue while the timer is paused which should ensure it is recorded at 0sec then begin the source timer and continue real-time settings from cue 2.
-Record Cue-List
-[Advanced Options]
-Store cue
-Store cue.
-etc.
-[Timecode]
-[Record]
