Hello
I have a Problem with Moving-Head^s Futurelight DJ-Head 250 Spot.
They have only a Shutter, no Dimmer ( Shutter closed - Strobe effect- Shutter open).
After run Chases, the Lamp are still on., Shutter open.
What can i do ?
Thank you for answer.
Problem with Fixture Patch
Only solution is to edit fixture personality and change the shutter channel to HTP
For example from the original:
change the L to an H:
DMX
2 61 L 15 100 1N O 1 "Shutter" 250 0 0
ENDchange the L to an H:
DMX
2 61 H 15 100 1N O 1 "Shutter" 250 0 0
END- john rogers
