live show and visualiser
lj bjorn
Postby lj bjorn » 07 Oct 2004, 15:46
i want to use the visualiser at the same time as i´m running a live show. (For the beter overvieuw)
but at the moment i start the visualiser de pearl 2004 V1 dmx output becomes unstable. that means all connected fixtures shake in there moves while the visualizer runs perfect. like a bit of priority high for the visualizer en dmx out low.
Is there a way to change the priority for dmx high and visualizer low?
Grts LJ Bjorn
Olie
Site Admin
Postby Olie » 08 Oct 2004, 09:55
I am afraid this is not possible simply due to the amount of processing power required to run the Visualiser over Midi. We do not recomend using the MIDI set to Visualiser while running a show.
We do have a solution though. You can buy an EzDmx box from us that will alow you to plug the DMX straight into Visualiser without the need for Midi. This is a USB device that allows you to input 8 Universes into your PC.
Hope this helps!
Steve Nield
EZDMX
Postby Steve Nield » 26 Oct 2004, 08:40
Where can I get info / spec / pricing on EZDMX
