Artnet Mapping Tiger touch version 4
MickMurray
I'm having trouble with artnet mapping on tiger touch, i mapped catalyst to output zero no problem on my current show, it worked fine, then i loaded another show that i am pre programming in wysiwyg and mapped the outputs, when i go back to my current show the mapping is there it isnt saved with the show (which i thought wierd) and when i delete the mapping the option to re map to zero is gone, each time i go to map it increases the universe by 1 as the next available universe! So i've now got catalyst patched to universe 6 as it was the only available artnet universe, am i doing something wrong? Is there a work around, is it possible to include artnet mappings / dmx mapping when saving the show?
Doesn't it make sense to separate universe mapping from the show, and treat it like a installation-dependend desk setting? Like: your show can be loaded into any desk, regardless if the desk in that very location is set (and connected) to DMX, ArtNet or whatever?
However: whilst the ArtNet universe is automatically incremented in the left pane (available nodes), you can neithertheless change the universe once a node is patched. Click the 'i' button of the patched ArtNet node (right pane), and change the universe ackording to your needs (usually, this is selected by default, so: click 'i', hit '0', hit ENTER - that's it)
Sebastian
Sebastian
MickMurray
O.k. i'll try that, and well the mapping is something that should be an option to be saved, if u are touring a show everyday you want to be able to save each day's specific setup, or as i am doing at the moment previsualising the show on days off before getting to venues, i program and save the show for that specific venue, i should be able to save everything and recall it. But no i have to go mess with mappings, all other desks in the same feature set that i know save patch info with the show file so i think it should be an option
