I have an Enttec ODE interface which is designed to work with Artnet. I can successfully use this with another software program on my ipad so i know it works. I am trying to get DMX line 1 to output Arnet. I added the Arnet node to Line one and set the IP address to the IP address of the ODE node but I am not getting any DMX output from the ODE box. If i fire up my ipad and enable arnet from the program on it, it works fine.
I am making sure that the ipad is not trying to drive the same node, but I still cannot get it to work. What am i doing wrong?
ross
Titan Mobile to Enttec Open DMX Ethernet
Ross Beiler
Freelance Designer
Ephrata Performing Arts Center
Freelance Designer
The laptop is networked with the Enttec ODE unit. The laptop (Titan Mobile) is in a control booth were all the dmx lines are used up. I am trying to get Titan to connect to the ODE node, send it ArtNet so that the ODE can convert it to DMX on stage.
I am trying to run another DMX line up to the control booth.
Ross
Ross
Ross Beiler
Freelance Designer
Freelance Designer
All sounds like it should work. Are you running through a router/switch? If so can you access the gateway from a browser (assuming it also has a web interface). Alternatively try pinging the Enttec box and/or switch if used. These would all be possible methods to determine if the laptop can communicate at all with the devices and understand if it's a networking issue or not.
Enttec comes with a software program that you can access the node with. Running from the same laptop that Titan is running from, it finds the node without any issues. I really needed this working last night. The DMX run from control booth to the stage was too long. Fortunately, one of the product guys had a dmx splitter that we installed in the line to get everything to work. Have another show there in about 10 days and really want to have this worked out. I will post some screen shots early this week after I sent things up again in the office.
Ross Beiler
Freelance Designer
Freelance Designer
