Upgrade of Tiger Touch
Olie
Site Admin
Postby Olie » 17 Jan 2011, 15:22
We have noticed that after running a V3.1 recovery stick the software display settings will default to connected instead of disconnected as in v4.0. This may cause windows to open on a monitor which is not connected. You may need to adjust this settings as detailed bellow.
Please note this only effects you if you have run a recovery stick, the setting will be correct after an update.
"After installing the software through a recovery stick, please set the External Display to Connected or Disconnected, as appropriate. This setting can be found in the SYSTEM Menu, option G “Display Setup”."
