Diamond 3 HTP Personality problem
janvanbree
Postby janvanbree » 27 Dec 2010, 22:07
Hello all,
I recently bought a D3 console and i'm currently fitting all my fixtures onto it.
The Problem:
We use a lot of Showtec Sunstrips (bar with 10 halogen bulbs wich all are independently dimmable, like 10 separate dimmers). When I patch these as dimmers it uses a lot of faders. I know for the Pearl 2008 there is a 10 dimmerpack personality (witch can run shape's as well). I couldn't find this personality for the D2/D3.
I tried to create a personality on my own but it has the problem that when I alter one channel, all the channels follow. This is what I made up. Can anyone help me correct this?
; Showtec Sunstrip 10 channel mode |
; personality for the Diamond II |
; History :- |
; Revision | Date | By | Description |
; 1.0 | 25-10-10 |J van Bree | Created |
DEVICE=SHTSUNSTRIP ; Device Name (upto 11 chars) must be enclosed in single
DEVICE23= ; 22 chars after '='
; extra information for softkey prompt lines 2&3
; a total of 22 chars, split into 2 lines of 11
; __ Number of lines of DMX info.
; | __ Number of lines of wheel info
HSTART 3 10 1b05 0 0 ff 0 1 10 10
; | | | | | | | |__ Line number for flash button DMX info
; | | | | | | | from DMX definition (1..x)
; | | | | | | |__ Button release value
; | | | | | |__ Button ON value (ff means use swop/add fader)
; | | | | |__ The TILT arc in Degrees
; | | | |__ The Pan arc in degrees
; | | |__ Date in PC format (1b05==5/08/93)
; | |__ Number of DMX slots used
; |__ Patch direction (0 for mirror, 3 for moving head)
TEXTSTART ; Upto 21 lines of 28 characters
Showtec ;
Active Sunstrip ;
10 channels ;
Created by Jan van Bree ;
(C) ALE Light & Sound ;
www.alelight.nl ;
TEXTEND
; For the Attribute Dictionary refer to file 'dict.per'
; DMX information
; No unused lines allowed between keyword 'DSTART' and last DMX definition
DSTART ; DMX Picture
1 1 0 0 0 0 ; Dimmer 1
2 1 0 0 0 0 ; Dimmer 2
3 1 0 0 0 0 ; Dimmer 3
4 1 0 0 0 0 ; Dimmer 4
5 1 0 0 0 0 ; Dimmer 5
6 1 0 0 0 0 ; Dimmer 6
7 1 0 0 0 0 ; Dimmer 7
8 1 0 0 0 0 ; Dimmer 8
9 1 0 0 0 0 ; Dimmer 9
10 1 0 0 0 0 ; Dimmer 10
;| | | | | |__ Spare (always 0 for now)
;| | | | |__ Attribute name (See list above)
;| | | |__ Curve (0 means no curve otherwise curve number)
;| | |__ Flags (7=inverted, 40=instant, 20=16-bit)
;| |__ Channel type (1=HTP, 2=LTP, 0=Dummy(for 16-bit defines)
;|__ DMX offset (1..255, 0 means DIMMER will be patched seperately)
; WHEEL information
WSTART
8 ffff 0 4 0 0 1 0 1 0 1 0 0 0 0 0 ; 1. Dimmer
8 ffff 0 4 0 0 2 0 1 1 2 0 0 0 0 0 ; 2. Dimmer
8 ffff 0 4 0 0 3 0 1 2 3 0 0 0 0 0 ; 3. Dimmer
8 ffff 0 4 0 0 4 0 1 3 4 0 0 0 0 0 ; 4. Dimmer
8 ffff 0 4 0 0 5 0 1 4 5 0 0 0 0 0 ; 5. Dimmer
8 ffff 0 4 0 0 6 0 1 5 6 0 0 0 0 0 ; 6. Dimmer
8 ffff 0 4 0 0 7 0 1 6 7 0 0 0 0 0 ; 7. Dimmer
8 ffff 0 4 0 0 8 0 1 7 8 0 0 0 0 0 ; 8. Dimmer
8 ffff 0 4 0 0 9 0 1 8 9 0 0 0 0 0 ; 9. Dimmer
8 ffff 0 4 0 0 10 0 1 9 10 0 0 0 0 0 ; 10. Dimmer
;A BBB CCCC D EEE F GG H I JJ KK L L L L L ;Name
;| | | | | | | | | | | | | | | |__L. List of Table channels as
;| | | | | | | | | | |___K. line numbers from DMX def.
;| | | | | | | | | | 0 means unused channel
;| | | | | | | | | |__J. DMX line (minus 1) pertainig to this wheel
;| | | | | | | | |__I. Number of chanels under control OR Table width
;| | | | | | | |__H. Table type (Attribute number) 0 means NOT a table
;| | | | | | |__G. Wheel number (1..8 on bank1, 9..16 on bank2 et cetera)
;| | | | | |__F. 0 for 8 bits, 1 for 16 bits
;| | | | |__E. Attribute name from above list (0..MAX)
;| | | |__D. Wheel type (1-offset, 2-Table, 3-Pan/Tilt, 4-Dimmer)
;| | |__C. Default/Locate value (left shifted as necessary)
;| |__B. AND mask, where more than wheel controls same DMX slot
;|__A. Wheel multiplication =16-(bits used)
; eg. for 8 bit channels it is 8, for 12 bit channels it is 4
john rogers
Postby john rogers » 30 Dec 2010, 20:33
I'm afraid there's no way for me to investigate this until after the Avolites office opens on the 4th January as I'd need to actually have the DIII in front of me to test if this is possible.
Hope that's okay.
janvanbree
Postby janvanbree » 30 Dec 2010, 22:51
no problem, every help's welcome!
