Toggle Mode switch = pearl tiger
Is this possible to lock "toggle mode" function/switch A in Pearl ? I have now Run Mode Takeover and i can't change it to Normal Mode. I have try in user settings and normally on screan with function button A and nothing, still Takeover. what may be the reason ?
EmmaThompson
If you have theatre stack mode active you will always be in takeover mode. Check you have not got this enabled by going into Program mode and pressing 'theatre stack' from the softkeys. If you have it enabled, there will be an option to 'exit theatre stack programming' - select this.
Emma Thompson
Training and Events
Training and Events
