SHAPE DISSAPEARS FROM CUE AFTER THIS CUE ITS BEEN KILLED
Chris
Postby Chris » 25 Nov 2010, 23:48
lets say I have two cues,one with shape movement values plus all atribute values active(dimmer,position,color etc) and another one with dimmer values(acls for example). I press swop button of acls' cue(add to kill) so everything else blackouts.When I release swop I should normally go back to the state of previous cue.Instead of that I get previous cue with all other values active....except shape.So I must move down the fader and up again to make it work propper or even better to press ''Pause & preload" and the shape will start playing again.Im using a D4 right now but if I remember well same problem exists in Pearl too.Unless is something explained in manual but haven't seen it.:?
Thank you!
Postby niclights » 26 Nov 2010, 00:37
I've not seen the problem, but this definitely doesn't happen in Titan which hopefully is not too far away for D4.
