Pearl Expert + Elo Touch Screen
Andygwk
Postby Andygwk » 11 Nov 2010, 18:52
Hi
I have an elo usb touch screen and was wondering if its possible to set it up on the pearl expert running titan. And if so how would i go about doing this.
Andy
EmmaThompson
Postby EmmaThompson » 12 Nov 2010, 11:54
Hey Andy,
Yes, you can use touch screens with any Titan console. You will need to install the drivers on the console, then calibrate the touch screen.
Emma Thompson
Training and Events
ricws
Postby ricws » 13 Nov 2010, 02:15
Hi Emma
Has Avo's position on touch screens changed then? Last I knew you discouraged the use of external touch screens because of potential problems with the drivers.
Olie
Site Admin
Postby Olie » 15 Nov 2010, 10:26
I recently had a customer trying to install an Elo touch screen and they where unable to get it working. So not all touch screens will work.
You must have an Expert with a Touch wing before you can install an additional touch monitor. You can then choose one of two models.
NEC MultiSync LCD195VXM+
iiyama ProLite T1731SR
Others may work but could cause your console to become unstable.
