bug! expert titan+chauvet legend 6500 pers
pixilpusher
Postby pixilpusher » 12 Oct 2010, 20:53
hey guys,
I'm on site at a show and the house has chauvet legend 6500 led movers. when i patch the fixtures i'm receiving an error message stating "error in personality, attributes will note be displayed correctly".
just updated the personality library.
tried using other personalities.
1 - pan
2 - pan fine
3 - tilt
4 - tilt fine
5 - pan/tilt speed
6 - red
7 - green
8 - blue
9 - white
10 - color macro
11 - dimmer
12 - strobe
13 - dimmer speed
14 - control
any suggestions would be greatly appreciate.
thanks,
matt
Postby niclights » 13 Oct 2010, 00:42
There is a fault with the personality where two attributes in the 'Advanced' mode are set to use the same wheel. The 'Basic' version is unaffected.
To fix:
Run Personality Builder application.
Open "Chauvet_Legend 6500.d4"
Expand 'Modes'.
Expand 'Advanced, 16bit'.
Select 'P/T Speed'.
On the right-hand side under 'Diamond 4 Wheel Mapping' click on 'D4 Wheel' and change to 'Wheel 2' using the drop-down selection on the far right.
Save & restart Titan.
Sorry if this comes too late for you. I was on a show myself. Hope you got it sorted in any case.
john rogers
Postby john rogers » 14 Oct 2010, 15:30
Thanks Nic, I didn't catch this one in time either :(
This change has since been added to the library.
Pixilpusher: YHM
Users browsing this forum: No registered users and 163 guests
