Touch screen on Expert and Patching mediaserver (Arkaos)
djz2005
Postby djz2005 » 24 Sep 2010, 23:50
Hi Guys
I'm new to this forum, and i need help for 2 questions
1. Can somebody please help me, patching arkaos on a pearl expert titan so that i can see thumbs?
2. is it possible to use a external touchscreen for an expert?
hope to get some help :)
Best Regards
Jacob Andersen
Designer | Technician | Rigger
Postby niclights » 25 Sep 2010, 12:23
Does this thread help?
djz2005
Postby djz2005 » 25 Sep 2010, 16:09
Hi i'm sorry to say... I need help to setting Up the CITP for recieving the thumbnails and i does not say in the thread...i'm not very good to networks :)
Best Regards
Jacob Andersen
Postby niclights » 25 Sep 2010, 18:19
Olie mentioned in that thread you might need a special patch to get thumbnails working for Arkaos at the moment. It also only works on the pro version according to other posts there.
If your problem is you cannot actually see the active fixture to patch because of network problems then check the manual section 13 for understanding IP addresses. I think that explains far better than I could here.
Postby icke_siegen » 27 Sep 2010, 09:24
at the moment, it's like this:
- for the CITP thumbnails, you would need a CITP update - a little file you need to install on the desk. Contact your dealer or Avolites service to get this file (will be present in the upcoming Titan version by default)
- with that, you can have the ArKaos thumbs on the desk. However, since in ArKaos VJ (the old one, version 3.6) only a limited subset of CITP is supported, you will encounter some strange behavior. E.g. changes in the ArKaos library will not be recognized by the desk unless you re-patch the fixture. Hence, you should at first invoke all videos into ArKaos before patching the fixture.
- full CITP support is reportedly present in the newer ArKaos versions (couldn't test this myself).
As for the (second) touchscreen: the Avos showed this on PLASA, hence maybe someone could specify suggested Touchscreen models...
Cheers, Sebastian
djz2005
Postby djz2005 » 10 Oct 2010, 23:40
Now i can see the arkaos on the touch tablet, but i can't see it on the console at a active fixture...how can that be?
Can sombody help?
https://dl-web.dropbox.com/get/Photo%20 ... w=8e1db939
https://dl-web.dropbox.com/get/Photo%20 ... w=a3bd9a6a
Best Regards
Jacob Andersen
Postby niclights » 11 Oct 2010, 00:09
Can't access those photos. Try Imageshack.
djz2005
Postby djz2005 » 11 Oct 2010, 00:12
Best Regards
Jacob Andersen
john rogers
Postby john rogers » 12 Oct 2010, 13:33
Hi, this may be an obvious question, so I apologise if you've already checked what I'm about to ask:
Are the Arkaos and the console on compatible network addresses?
If so have you tried running the devices through an Ethernet router?
djz2005
Postby djz2005 » 12 Oct 2010, 13:58
Hi John
What dó you mean about compatible adresses? Should they have the same adresses? The console is named 2.0.0.1 and the mediaserver 2.0.0.10...what would it help to put ón a router/switch if i already Can see it through the touch wing :) hopes somebody Can help me with These informations :)
Best Regards
Jacob Andersen
john rogers
Postby john rogers » 12 Oct 2010, 14:52
Hi, no you shouldn't have them on the same IP address, the ones you have there are fine.
You should also check the subnet mask on both devices is 255.0.0.0
You could also try turning off the firewall on your Arkaos, in case this is causing issues.
djz2005
Postby djz2005 » 12 Oct 2010, 14:56
Yes the submask is set to that, and i Think the firewall is off, or Else i couldn't see it ón the touch? I can't figure out what i am doing wrong :-s
Best Regards
Jacob Andersen
john rogers
Postby john rogers » 12 Oct 2010, 15:09
Have you updated to the latest version of the personality library? http://www.avolitesdownload.com/PersonalityFiles/Downloads/PearlExpertTitanFixtureLibrary.exe
Also, can you tell me how many layers your Arkaos is running and if possible the software version number.
Thanks for your patience, we'll get this figured out soon!
djz2005
Postby djz2005 » 12 Oct 2010, 16:44
i cant't tell you if the personality library is the latest...beacuse it's a brand new console :) do you think it will work?
i am only using one or two layers to begin with, and the software number is 3.6 dmx...
i should tell you i am a total newbie at usig artnet :-s
Best Regards
Jacob Andersen
john rogers
Postby john rogers » 12 Oct 2010, 17:37
I'll update our Arkaos in the office in the morning and test it against a Pearl Expert and go through it with you that way.
I'd still update the library in your desk as we release new updates to personality files five time a week!
