Tiger Battery
macdiv
Tiger Battery
Postby macdiv » 10 Sep 2010, 13:37
Hi every one , my tiger doesn't want to boot and giving my the lovely whit and blue lights without no thing there ,,,,so i open the disk and the check the battery and i find it almost zero !!!!!! is it normal for the battery to be worn or become 1volt after less than 1 year of usage !!! my disk is brand new with the plastic protective bottom sheet still there !!!!! any how i got to work so i got new battery and before replacing it i measure the volt across the battery in the Boris mother board before inserting the new one ,, and i found that there is no volt for charging !!! any body have any clew it should be DC source to charge the battery ,,, i dont want to destroy the new one .....could any body help :roll:
losmichal
Postby losmichal » 12 Sep 2010, 14:35
its normal for avo becouse is not rechargeable battery its normal baterry
the avo say its should work for about 5year my one is death after 1 year u heve to replace battery and relicense avo if it lost
Michal
macdiv
Postby macdiv » 13 Sep 2010, 12:44
OK and thanks .. i just didn't expect that a console with that technology and good reputation like Avo tiger to have a worn battery after one year ,,i have some Zero 88 console working for 7 years till now with VARTA battery working like a rock ,,,,, OK i will replace it and re license ....thanks again
Postby niclights » 13 Sep 2010, 12:59
I think you should contact service direct and find out what is known about this problem and how they can help. I'm sure it's not normal. Even an old 2000 console I have here is still fine after almost ten years.
macdiv
Postby macdiv » 14 Sep 2010, 12:02
niclights wrote:I think you should contact service direct and find out what is known about this problem and how they can help. I'm sure it's not normal. Even an old 2000 console I have here is still fine after almost ten years.
i already contact them and they said replacing the battery is the solution for this problem ...
