Weird behaviour brightness in pallets
(iCe)
Postby (iCe) » 30 Aug 2010, 15:54
I don't know when this became possible, but it seems you can now record brightness into pallets with Titan? I don't think I'll be using that often, but for those who will: brightness recorded in a pallet seems to always produce output, even with all the masters lowered to 0. That can't be right I think?
Postby niclights » 30 Aug 2010, 16:29
Intensity palettes are mastered by grand master. Are you sure you have this enabled (user settings)?
(iCe)
Postby (iCe) » 31 Aug 2010, 14:27
Whether they are controlled or not is a setting? Didn't check the user settings since I didn't know they were there. The only thing I know for sure is that I could produce output on movers while all masters where lowered; by pressing a pallet button.
Postby niclights » 31 Aug 2010, 17:20
I think my wording was confusing.
It is not a setting specific to intensity palettes, but just grand master enable/disable. This replaces the Classic 'grand master broken' user setting.
With GM enabled everything (including intensity palettes & programmer) is mastered by it.
(iCe)
Postby (iCe) » 31 Aug 2010, 19:44
Well, the rest got dimmed ok, but those were playbacks and regular faders, so I'm not exactly sure. Wouldn't the default setting be that the grand master works as it should? I sure can't remember changing that, but I'll check tomorrow.
