Hello!
I'm trying to figure out how to create a 'wave' shape across moving heads! What I mean by this is that Moving Head 1(MH1) starts a basic shape then MH2 starts the same shape after a short delay then MH3 starts the shape after a delay etc etc etc and it keeps going round.
I know the Pearl Expert has a Colour wave shape generator option but I want to do the same thing with movement!
Is there a shape I can download to do this?
I'm using Mac 250 Entours (Mode 2)
It's probably really simple but I'm new to it!
Cheers!
Moving Head Wave - Pearl Expert
You need to adjust the shape spread.
In the shape generator there are three softkeys that change which shape attributes you control with the wheels: [Speed/Size], [Phase/Spread], [Phase Offset] (ish!)
After creating your shape press [Phase/Spread] and increase the spread value. To achieve a flow across all your heads simply set the spread to the total number of selected fixtures. Phase is the same thing but gives finer control. The phase/spread is applied in the order you select your fixtures.
