Vis files
iadwm
Vis files
Postby iadwm » 02 Jul 2010, 14:59
Is this the correct procedure to add Vis files to a TITAN Expert?
Use Personality Builder to create/edit the D file
Save to Avolites/Titan/Fixture Library
Then generate (via Personality Builder) the .R20 file
Save to Avolites/Personalities
Use the .R20 with VisWiz to create the Vis extension
Save .vis to Avolites/Visualiser/Extensions
I'm getting a bit confused trying to get two fixtures to appear in Vis,
I know it's because one of the files doesn't exist. Specifically Futurelight SC780 and Martin Destroyer. I guess if the .R20 is missing then the .vis is going to be as well? Unless one has accidentally been deleted....
Cheers,
Andy
John Peel
www.iadwm.com
Postby niclights » 02 Jul 2010, 17:51
I don't know about procedure, but the .r20 file needs to be in Avolites/Visualiser/Personalities. The other folder is for classic.
The device name (not filename) must be the same between the .r20 and .vis files and for auto-patch to work this device name must also be in the 'classic pearl reference' field within .d4 modes.
Use the online library to find out which fixtures exist for Vis.
Users browsing this forum: No registered users and 66 guests
