Expert Monitor size
ricws
Expert Monitor size
Postby ricws » 25 Jun 2010, 19:30
Hi I have a Pearl Expert w/ touch wing on order and was wondering if any body had any recommendations for the size and aspect ratio of the monitor.
Thanks.
Postby niclights » 25 Jun 2010, 19:35
I use 19" widescreen. This works nicely for the HUD width and lines up almost perfectly with the rollers (including via VESA mount). The advantage of the widescreen ratio is you get this width without the height getting in the way of the stage.
ricws
Postby ricws » 25 Jun 2010, 21:43
Thanks for the very helpful Info.
Now all I need is the console. (It's been over 7 week since I ordered it.) javascript:emoticon(':?')
davewarehouselx
Postby davewarehouselx » 28 Jun 2010, 12:29
I've been using a 24" widescreen as this lines up nicely with all of the preset handles. It's worth considering an Ergotron height adjustable monitor stand as well - it allows you to get the screen in a great position for programming and then move it out of the way if necessary to see more of the stage:
http://www.ergotron.com/Products/tabid/ ... fault.aspx
Cheers
Dave
