Problem with Tiger touch
Stratis
Postby Stratis » 22 Jun 2010, 11:21
I have just installed version 3.1 on my tiger touch but i get an error on the time the touch software boots.The console cannot locate the file shape.xml
from path program files/avolites/titan/fixturelibrary.
Without this i cannot use shape generator because it is empty.I tried reinstalling the software but the error continues.I couldn't find the version 3.0 of tiger touch to go back.
Jonathan
Postby Jonathan » 22 Jun 2010, 12:07
Downloading the latest personality library will fix this problem.
To do this
- Go to the Personality Library
- Select Downloads then Tiger Touch
- Click Download Personality Library
- Copy and run the file on the Console following the on screen instructions
Avolites Fixture Support
Stratis
Postby Stratis » 22 Jun 2010, 13:19
i have installed the late personality file but the problem still exists
Postby niclights » 22 Jun 2010, 14:12
Did you restart the software after installing?
Jonathan
Postby Jonathan » 22 Jun 2010, 14:32
Try downloading and installing it again we have fixed an issue with the shape file in the library generated this morning.
Stratis
Postby Stratis » 22 Jun 2010, 14:47
Yes i restarted the software an then i installed the library and it worked fine.then i restarted the console an the error pope up when the titan was loading.i have downloaded a new fixture library but the problem still exists.I will test it tomorrow again.
