Found a bug in new titan software:
if you recall palette with long fade time (20s) and then quickly decide to fade another palette (for same parameter) with short time (1s), it normally fades to second palette, but at the moment when first palette fade should end, parameter value jumps to first value.
For example, if we take 2 position palettes:
select some fixtures
enter fade time 20 with keypad and recall 1st palette
quickly enter fade time 1 with keypad and recall 2nd palette
it fades to 2nd palette in 1 second and stops at 2nd palette position
after few seconds (at exact moment when 1st palette fade would end) it jumps to 1st palette position
Titan pallete fade problem
