Titan Classic mode issues
masoundbob
Postby masoundbob » 03 Jun 2010, 14:34
Version 3
96 channels of dimmers- all conventional show.
Using the console in Classic mode there is a 1-2 second delay on the swap, add buttons. There is also a noticable delay when you snap a fader up.
Also- if you hold down a swap or add on the playbacks and swith to program mode the console locks the faders.
When you go back to run or takeover, tap the swap button, move the fader up and down once the faders quit working. The only way to get them back is to do a panel reset.
:roll: If you are wondering why someone would do the above- I had an LD decide to try and write a cue while in the middle of bumping fixtures.
I did a repatch in Titan and all worked fine, it seems to only be in classic mode.
Bob Williams
