fixture solo
andre
fixture solo
Postby andre » 05 Apr 2010, 18:48
hello,
liked to help me in pearl 2008.
for example the robots have shaped pan and tilt with the color yellow.
when lifting the playback fader want they are going to position the guitar for example with white color and shape I want to stop the pan and tilt.
Postby niclights » 05 Apr 2010, 20:04
In the solo playback record a circle shape with size zero.
Set the solo playback to mode2 ([Edit Times]/toggle mode until =2 and press enter).
andre
fixture solo
Postby andre » 06 Apr 2010, 00:22
but my problem is:
I have a tilt movement running.
and have recorded a playback position for a guitarist, so when he soles
What happens is:
when I raise the fader to position the robots continue to tilt, and had spent the edit times for 2 ....
SL
Postby SL » 06 Apr 2010, 02:21
You have to program an shape with your solo position. So make your position, go to the shape generator and select a circle shape. Make the size 0, and record it on the playback you want. Then go to playback parameters in the Shape Generator menu, and select your playback. Then somewhere the desk say 'set to Mode 2' and select that. Than it has to work.
(Again, sorry for bad english ;) )
andre
Postby andre » 07 Apr 2010, 17:06
thanks that was exactly what I needed, but I never had remembered that way.
andre
Postby andre » 07 Apr 2010, 17:21
only got one more question!
I set the color palette through the flash ....
then when I raise the fader playback, I want the color to be white.
how do I playback fader is higher than the flash color palette?
Postby niclights » 07 Apr 2010, 22:35
Mode 2 will make that work.
Solo cue contains white colour, position, circle shape size 0 and is set to mode2.
Choose normal colour with palettes.
Raise solo fader changes colour to white, moves fixtures to solo position and stops shape.
Lower fader restores to previous colour, position and shape runs again.
However, any values that are in the programmer will not be affected by the playback. So if you select fixtures before recalling the colour palette then you must press clear for the white solo to work.
To avoid palettes going into the programmer you can use Quick Palette mode which allows you to recall palettes without selecting fixtures. You can turn this on in user settings.
Users browsing this forum: Bing [Bot] and 49 guests
