make a step go in reverse in an unlinked chase?
Tumbleweed
is there a way to step backwards in unlinked chases on a Pearl 2008/2010?
Tumbleweed
Sorry, I'm not sure if that was a question or not?
To clarify, if there is a change of direction when using the chase control buttons it does not snap to the next step. So this would not be a problem. Otherwise I always found that a useful feature. I can't remember if there is a difference when Fixture control is enabled and you use the arrow keys instead, but I didn't think so.
To jump directly to a step enter the step number followed by Connect. Pressing Go will then go to that step with associated timing. This works for theatre stack too. I don't think it was ever documented.
