pearl expert r20
brioljuris
pearl expert r20
Postby brioljuris » 14 Dec 2009, 14:26
hello guys,
ive got a little situation about my pearl expert.i tried to create r20 file for my fixture using the r20 personality builder.unfortunately,i dont think pearl expert can load or read it.is this possible or not.i used to do this with pearl 2008 and 2004 and the pearl tiger with no gliches.i just can fure out why i cant have it working in the expert.
would apprciate any help extended.
thanks much,
iadwm
Postby iadwm » 14 Dec 2009, 16:56
If you are running TITAN, the Expert uses personalities from the D4 fixture library (.d4) and is completely different from .r20
Assuming you have already checked the fixture personality library, you will have to write/edit your own using a text editor or submit a request to Avo via the personality site.
The other option is simply to patch the fixture as dimmers.
If you're not running TITAN - then you should be!
http://www.avolitesdownload.com
HTH
Andy
John Peel
www.iadwm.com
Postby niclights » 14 Dec 2009, 20:11
Are you trying to read it from floppy/usb? The Expert won't do this. Instead you need to open Explorer and manually copy it into the classic directory: C:\program files\avolites\personalities\r20\
Regarding Titan personalities you wouldn't normally use a text editor to create your own. At a push you could use an xml editor but there is dedicated software available on request.
iadwm
Postby iadwm » 15 Dec 2009, 16:04
Ah...
Who do we contact to get hold of the editor software?
Andy
John Peel
www.iadwm.com
Postby niclights » 15 Dec 2009, 18:00
Speaketh to fixturesupport at avolites.com and prove yourself worthy.
iadwm
Postby iadwm » 15 Dec 2009, 18:13
Blessed are those at fixture support, keepers of The Atributes...
John Peel
www.iadwm.com
brioljuris
Postby brioljuris » 19 Dec 2009, 04:23
thank you so much guys for all the tips.
ill post as soon as i am able to work on your tips.
thanks
