Cues switching order in theatre stack mode
blackraven76
Postby blackraven76 » 21 Nov 2009, 23:36
i am having problems with a 2010 board in theatre stack mode. it is switching cue order from forward to backwards. i am not pressing any strange key order. i was running a show just fine and it switched to running cues backwards. had to type in each cue. very annoying.
(iCe)
Postby (iCe) » 22 Nov 2009, 11:45
You sure you didn't accidentally switched the order with the direction keys? Happened to me a few times, especially when operating boring shows and your hand is leaning on the console part where the direction buttons are too.
blackraven76
Postby blackraven76 » 23 Nov 2009, 01:50
yes that was it. thanks. i never had that issue before. i will watch out for it when i run show in theatre stack again.
Postby niclights » 23 Nov 2009, 12:51
You could perhaps prevent the possibility by toggling those buttons from chase control to fixture solo? (shift+softkey)
