Master speed control in titan
GARSTY
Postby GARSTY » 04 Nov 2009, 17:07
Hi
Is it possible to have master speed control over different attributes in a cue stack.
e.g.
cue 1 all heads dimmer 100 %
cue 2 all heads dimmer shape
I sometimes do these stacks to save on faders so you can go from straight on to a nice dimmer effect with ease. Having a separate fader that could control the speed of the dimmer shape would be great especially if you are busking.
If I have missed something and you already can could someone show me how.
Thanks :D
Postby niclights » 04 Nov 2009, 17:53
You know that you can set fader to control speed in cue-lists? Does that help?
I know the whole shape speed/size thing isn't ideal esp. for dimmer but hopefully this helps a little.
GARSTY
Postby GARSTY » 04 Nov 2009, 20:06
Hi Nic,
Thanks for the reply, where do I find this. Just so you know I am running V2 software.
Postby niclights » 04 Nov 2009, 20:18
Playback options, same as cues.
