RGB mix on the Azure.
toffs
Postby toffs » 25 Sep 2009, 12:55
Hi Folks,
We have a venue with an azure for control and have recently installed 20 LED cans.
When i select these units i can colour mix no problems at all.
However when i save the units as all red to a fader, one for all green and one for all blue i cannot mix with them.
How would i go about creating 3 faders that would allow me to quickly colour mix the fixtures on the fly?
We have a gig this eve so any response would be fantastic.
Thanks in advance.
J
Postby niclights » 25 Sep 2009, 15:23
Either use/create a personality where the attributes are HTP or set playbacks to mode2 (edit times).
toffs
Rgb mix
Postby toffs » 25 Sep 2009, 17:23
How do i change the mode that fader is in?
Cheers for your help.
Postby niclights » 25 Sep 2009, 17:34
Edit Times on a Pearl. I make the assumption it's the same on an Azure.
lightning
Re:
Postby lightning » 07 Jun 2015, 20:01
niclights wrote:Either use/create a personality where the attributes are HTP or set playbacks to mode2 (edit times).
Bump thread.. I'm trying to do this on v9.. but when i do mode2 for edit times on a playback fader it crossfades.. if I have red up 100%.. then slide the Green fader up the red starts fading out proportionately.. (when Green is at 50%, red is at 50%, when green is at 100%, red is 0%) i can never have red and green up 100%.. i want to be able to quickly build colors on the fly using 3 faders (#1 R, #2 G, #3 B) (not wheels).. TIA..
Re: RGB mix on the Azure.
Postby niclights » 07 Jun 2015, 20:40
This is because you have recorded more than one colour component in each playback. Use record by channel and make sure only one component is in the programmer.
